Root Directory of CGI Scripts
I would like to run CGI Scripts, can anyone tell me what is the root directory for CGI scripts on the server?
Hi Scott,
You can find it in the "cgi-bin" folder in the directory where Apache is installed. Actually, you can execute script from any folder on your file system. On my server, where I install the XAMPP web server, I can find it in C:xamppcgi-bin directory. There is a sample inside the directory named printenv.pl, you can try executing it using Perl that can be found in C:xamppperlbin. To allow scripts to run in the root directory you're going to change the "Directory" section.
For example:
<Directory /path/to/root>
Options +ExecCGI
</Directory>
You can find more information about cgi in this web site.
I hope it helps.
Notifications
