Root kit revival help – Windows 7
I am running Windows 7 ultimate x86 on my system.
Accidently I set up a virus.
Then I used combo to fix it but it shows me error 80096001.
I study somewhere that if the normal windows update repairs don’t work, then you have to create a new administrator Id and perform something from there; however I can’t discover the site another time to get out exactly what I have to do.
Always I turn off the system restore; as a result I can’t make use of that.
Mention that, I have never used any antivirus till now.
ComboFix – ZeroAccess
You are infected with Rootkit.ZeroAccess! It has inserted itself
into the
tcp/ip stack. This is a particularly difficult infection.
If for any reason that you're unable to connect to the internet
after
running ComboFix, reboot once and see if that fixes it.
If it's not fixed, run ComboFix one more time.
                                OK
Please help me to solve it. Thanks.
