Rosetta Stone version 3 Setup failed
Recently, I tried installing Rosetta Stone Version 3 which is a language learning software into my computer.
However, the installation failed repeatedly, and I got an error every time while trying to enter the setup process.
The error message is as follows:
Rosetta Stone Version 3 Setup
There is a problem with this Windows installer package.
A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.
![Rosetta Stone Version 3 Setup](https://www.techyv.com/sites/default/filesx/users/Images/There-is-a-problem-with-this-Windows-installer-package.jpeg)
Would anyone be kind enough to tell me what I need to do to eliminate this error?
I would be most grateful to the person who happens to know the solution to this because I really need to access this software.
I would anxiously await your replies.
Thank you in anticipation.
