Jeo Tolbert
Posted on - 08/27/2012
This error is so annoying, I think every time that the computer has to process or open an application related to roxie this error always appears, I can't even uninstall roxio so what am I going to do?
Roxio Easy Media Creator 10 Suite
The feature you are trying to use is on a network resource that is unavailable.
Click OK to try again, or enter an alternate path to a folder containing the installation package 'Roxio Easy Media Creator 10 Suite.msi' in the box below.
Use source:
C:DOCUME~1JEFFLOCALS~1Temppft18.tm
Roxie media creator error always showing
Dear Jeo,
It appears your installation of Roxio was not completed properly. That is why it is prompting you to insert installation media. If you installed Roxio from a CD-ROM, you need to insert it when this error appears. If you installed it by downloading the setup file then find out where it is. If you lost it you can download here again:
After downloading, click on browse in the error window and navigate to where your new downloaded setup file is and click OK. It will access it and reinstall/repair as needed, after that the error will not appear. You may also need to reboot once after it is done using the new setup file. Hope this helps.
