RSL Error 1 of 1 and also (Error #2032)
When I try to load the adobe flash player, I have encountered an error message as 'RSS ERROR 1 of 1'.
It is also mentioned 'Error #2032' at bottom of the player.
This is my uploaded error image,
Please help me from this error
Thanks,
Best Answer by cathy emrald
Answered By 0 points N/A #126602
Flash player "error 2032" is the result of incorrect code by the programmer.  It is unlikely that an end user will encounter this error as most programmers thoroughly test their Flash applications before putting the Flash file live on the internet.  If you are a regular visitor (not a programmer) and are experiencing this error it is most likely due to an error by the programmer- there is little that you can do to solve this error.
However if you are dead sure that the web content you are viewing is correctly coded (programmed) then you should reinstall Adobe Flash Player.
Solomon
Answered By 5 points N/A #126604
Error 2032 occurs if your Adobe becomes unresponsive. And it may be with the following reasons:
1. You have an invalid proxy settings.
2. Your website is under the restrictions lists.
3. You have a corrupted cookies.
4. You have add-ons installed that is not running properly.
5. Your registry is corrupted.
Check all the above workarounds to resolve this issue.
