Run A Microsoft Easy Fix Solution On Your System.
Hello, everyone, I want to know how I can run a Microsoft easy fix solution on my system to solve the problems. Thanks in advance for the help.
Follow the given instruction to run a Microsoft easy fix solution.
In the KB article which hosts the solution hit the download button or select the “fix this problem” link.
The dialog box of the downloaded file will appear.
• The down picture is of the downloaded file in internet explorer 11.
• The download file will prompt at the bottom of Google chrome33.
• You can also download the file in the Firefox.
After downloading the file, run it on your system.
You have to provide the credential when asking for.
Just proceed step by the prompts to fix the troubleshooting process. The prompts depend on the kind of package you downloaded.
Unfortunately, at the moment, Microsoft is no longer providing support for the “Microsoft easy Fix” solution because it has been retired. “Microsoft easy Fix” was originally known as “Microsoft Fix it” which helps users diagnose and fix problems for Microsoft products or third-party products that affects Microsoft products. There are two types of the Microsoft easy Fix package that users can download: an MSI (.msi) and .diagcab file.
The MSI type (.msi) was designed to work for Windows XP and Windows Vista while the DIAGCAB type (.diagcab) is for Windows 7 and higher. To use Microsoft easy Fix, just download the file, run it, and follow the instructions, that simple. Also, the Microsoft easy Fix tool is available specific to some problems.
You don’t just download it when you want it because it may not be useful to the problem you are experiencing. Anyway, try downloading Microsoft Fix It Center.
