Run Autoit Windows api copy
I tried to run Autoit with the rundll32 and i just get a windows error box saying this program must close. Please resolve my problem and suggest me How autoit windows API copy function works? Thanks!
Regards.
Regards.
Dear Matthew Leon,
This type of error usually occurs upon installation. Don’t worry about it. There may be some installation problem. I recommend you to use the following method to fix this type of issue. Here is the method:
1. To fix the rundll32.exe error use the key which is free find it here.
2. Download it and install in your system.
3. When installation completes you can scan your system easily.
4. Click "Repair Problems" to start to fix the rundll32.exe error.
5. Besides fixing the rundll32.exe error, Registry Easy can also remove any registry, start-up and run-time errors.
The link below will help you out to use AutoIt Windows API copy function that also contains its features and its functions too.
