Run a DLL as an App has encountered a problem
Hi guys,
I just changed my hard disk with all the old files including the ones on C but still installed my old hard disk as master.
When I try to boot up my pc and I get this error message:
Run a DLL as an App
Run a DLL as an App has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem.
We have created an error report that you can send to help us improve Run a DLL as an App. We will treat this report as confidential and anonymous.
To see what data this error report contains, click Here.
                                                Send Error Report            Don’t Send
Thanks guys.
Best Answer by Sharath Reddy
Answered By 590495 points N/A #123458
Maybe when you changed your hard disk there are files that were accidentally transferred to the other drive that was used by the operating system. If these files are required by Windows it will make your operating system unstable.
But since you already transferred the files it would be impossible to determine which of those are required.
If you think Windows is stable enough and you can still manage working with it then just close the error displayed.
But if you are done seeing that error message every time you open your computer you need to format your hard drive and install Windows again.
But to make sure that this is not an activity done by a virus, you may update your antivirus and then run a full-system scan on your computer.
Answered By 0 points N/A #123459
Try running System File Checker.
You may need to have your Window XP media ready in case the process would need to have it in your computer to overwrite corrupted or add missing system files.
To run this go to Start, All Programs, Accessories, then click on Command Prompt.
A black window will open then type in sfc /scannow. It will start the process and will show you a progress bar.
This will take several minutes to about an hour.
If there are no problems detected windows will just finish but if there are, it will ask you to insert the Windows XP cd that you used to install your copy of Windows into the optical drive.
