Chris Toper
Posted on - 07/04/2011
After installing some programs last week, I started to receive this error "Error loading jyku.fjo. The specified module could not be found." whenever I turn on my computer. I’ve been worrying a lot if this would have a great effect on my computer specially its performance and stability. I really do not know if this is a serious error or not.
If anyone knows how to get rid of this please do help.
RUN DLL error loading jyku.fjo
Jyku.fjo is a type of malware that hits your computer system. To remove it, follow the steps below:
1. Disable the System Restore feature temporarily and then reboot to Safe Mode.
2. Search and locate the jyku.fjo virus and uninstall it.
3. Go to your Registry Editor and then remove any values that are added to the Registry that are related to the virus file jyku.fjo.
4. Delete the entire Internet Explorer Temp files manually including the jyku.fjo and then run your antivirus program and scan your computer completely.
5. When the virus has been removed, enable the System Restore feature again.
Another way to fix this is to go to AVG website below:
AVG Support: How to handle infection suspicion?
That is really a pain but don't fret. Try this:
Go to Start menu, click Run and type "regedit"
Go to edit tab and click on find then these steps:
In the Find dialog box, type FILENAME. The name this suof the first found registry value referencing jyku.fjo is highlighted in the right pane of the registry editor window.
Right-click the registry value name and select Delete on the menu.
Click Yes in the Confirm Value Delete dialog box.
Do these steps to delete other reference to jyku.fjo.
logictor
5 points
Download the CCleaner software to fix the registry of the system, then install Ccleaner>>>run and scan. If these issues will not resolve just visit this link and read carefully the instruction of Stein that he give.
Thank you, hope it helps
Regards;
logictor
