anonymous
7060 points
Posted on - 08/08/2011
Good Day!
Whenever my computer is opened, I get the following prompt: "There was a problem starting C:UsersABRACOSAAppDataRoamingjiqie.dll. Access is denied." I don't know what caused it since the last time I used the PC, it is well. My PC is just recently reformatted and the programs are all newly installed.
The recent was the MS Visual Studio 2010 however, I didn't got this prompt after I installed it. It was days after all the installation are complete and working that this prompt occurred.
I don't know what triggered it.
Please help.
Run DLL prompt error at computer start up
DLL files are mainly a code shared by windows registry with other application. Sometimes the program doesn’t allow accessing this code and such error occurs.
A good registry cleaner may fix this problem.
http://www.regcure.com/lp/revenuewire/11/
Try this link for scan and repair the problem. For this purpose you have to visit Windows Registry File System. Then Click Start Click Run Type regedit and Find this registry key: HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > RUN.
In the right section click on the error file and Delete the value and Restart.
If the above solution doesn’t work then the best way to figure out this problem is to delete the Rundll Errors. Now we will discuss it in detail.
Firstly you should identify the specific Rundll process. Visit www.processlibrary.com and paste the error path in the search box to identify the process.
Secondly stop the process by just going to START menu and then clicking Run. Then type in there services.msc, now you can find your infected file and Click stop the Dll Service.
