Run Peazip Files on Window-Based PC
I want to know if its possible to integrate Peazip Files with Windows using Winrar or Winzip?
If no, is there any other way that I can open Peazip files with both Windows and Linux PC?
It is possible to run Peazip files on Window-based PC. Peazip is designed as compact software that can be established with both Windows and Linux. To install and uninstall Peazip on Windows, please follow the steps below:
Unfortunately not, WinRAR and WinZip don’t support the extension name or file format used by PeaZip which is pea or .pea. If you have some PeaZip files on your computer, just download and install PeaZip Free Archiver. It supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit.
PeaZip is a free, open source file archiver and file manager developed by Giorgio Tani designed for Microsoft Windows, Linux, and BSD. It is basically written in Free Pascal using Lazarus. The letters “PEA” in PeaZip stands for “Pack Encrypt Authenticate”. Here are a few limitations of PeaZip:
