“Run – time error ‘372’:
Lastnight I downloaded  MalwareBytes from the internet.
Later when I proceeded with running it, The hereby shown error appears,
Runtime error '372'
Malwarebytes Anti-Malware
Run-time error 372:
Failed to load control ‘vbalGrid’ from vbalsgrid6.ocx. Your version of vbalsgrid6.ocx may be outdated. Make sure you are using the version of the control that was provided with your application.
OK
I need an urgent solution.
Please help as early as you can.
Best Answer by JOY Schilling
Answered By 5 points N/A #140109
Hi Janetdschall,
This is a compatibility issue or file missing issue. To resolve this you can try replacing the ocx file updated version. To find the updated version you have to visit the Google and search with the ocx file name. You will find many sites that are providing ocx file for free. Just download the required file and replace with the previous version and try again.
Hope you will get better result. Good luck.
Answered By 5 points N/A #140110
You got the error message saying “Runtime Error: 372 – Failed to load control <controlName> from <control.ocx>.Your version of <control.ocx> may be outdated. Make sure you are using the version of the control that was provided with your application.” Because you tried to run a Visual Basic 6.0 application that contains and ActiveX control.
This might have occurred if it the program was run from a user account other than the one which the program was initially installed from. To solve this problem, you will need to modify the program so that it is installed for all users on the computer.
