I am having problem sending emails. I have created a long macro that imports info from worksheet and need to send them to multiple email address. But it never completes sending them.
I mean sometimes it sends out a few emails, sometimes all, sometimes half. It sends email randomly. Also I get an error message like –
RUN-TIME ERROR '7000'
NOTES ERROR DATABASE ALREADY CONTAINS A DOCUMENT WITH THIS ID
(UNID)
Run-time Error ‘7000’ cause email error
You should know that the concept of Runtime error 7000 to fix it and also identify immediately the cause of the problem. Runtime error 7000 is an error that usually occurs when a DLL file is not registered or not found on your computer.
It is a very common problem for Windows users that crashes now and then.
1: You can register again the registry list to fix this problem since Runtime error 7000 relates to missing DLL files on your computer. Please do the following in order for you to register again your DLL files:
1. Go to Start and select Run
2. Type the command “regsvr32” and go to c:windowssystem32dllfile and download the repair tool from the link given below
3. Then, restart your computer
Download the file from the internet if you can’t find the specific file in your computer and then put it in the specified location.
2: You can also try to run a free registry to fix this issue by scanning your computer. It is recommended as the most important step for you to fix Runtime error 7000 and possibly avoid other runtime errors effectively.
There are numerous registry repair tools available on the Internet that scan, analyze, and then fix your computer. These tools will remove any registry errors, not valid shortcuts, duplicated files and repair the DLL files besides fixing your Runtime error 7000.
Your computer will be free from system errors eventually and improve the sluggish performance. You must fix Runtime error 7000 as well as other registry errors to prevent total corruption of the registry of your computer.
If you don’t fix this problem right away, this might even lead to more troubles in the future and eventually even system crash. You can fix this type of error in a fast and cheap way.
You can have this excellent solution and it is proven to help you fix PC error and even improve the performance of your computer. Download now.
