blackjan
Posted on - 10/09/2011
Last night, I create a photo show or slide show maker. I use wedding album maker. When I’m near to finish my slide show I think 98% to finish, then the messages show in the screen Runtime errors the slide show stop responding.
I close the application. Until now I can make a slide show for my customer especially in the wedding guest. What is the cause of runtime errors?
Please help me.
Blackjan
Crooke
RUN TIME ERRORS DISPLAY MESSAGES
Start up loading files of your software are crashed are interrupted with any other software which stop it from running. So I think you must uninstall this software fro your system, restart your system and Install this software again. And open that required related file in this software. I hope now it will work properly without any problem.
If again you facing same problem than believe that software installing source is not good so update that software on internet to recover that problem and you will get more excellent and updated result with that new version. Keep your system away from harmful scripts.
Are you using this software first time or you are a regular user of this software. Secondly I want to know do you face this issue first time? In a common errors, runtime error appears when your media supporting plug-ins not working probably. Try to update your Quick Time, Encoders etc.
If you still face this problem. Try any other software and check it, is the same error appears. Let me inform about your usage of software history than I will able to give you any proper solution. The above mentioned solution are very common, I hope it will resolve your problem.
