Run two Skype accounts at the same time
I want to log into two Skype accounts at the same time,is their any way to do that,please anyone help me,because i want to use one account for my family and other account for my business
Hello Carly,
Running two Skype accounts at the same time on one computer is easy. Basically it's possible by running 2 instances of Skype at the same time. Normally, Skype will not let you open more than 1 instance of it. Here's how to workaround that limitation:
1. Look for the EXE file of Skype. It is usually in C:Program Files (x86)SkypePhone (if you are using 64-bit Windows Vista or 7) or C:Program FilesSkypePhone (if you are using 32-bit Windows XP, Vista, or 7).
2. Right-click on the icon. Select "Send to" and then select "Desktop (create shortcut)".
3. Locate the shortcut on the desktop and right-click on it.
4. Select "Properties".
5. In the Target text box, add: "/secondary" (without the quotes).
6. The result would be something like this: "C:Program FilesSkypePhoneSkype.exe" /secondary
NOTE: the "/secondary" is what makes it possible to run the 2nd instance.
When you need a 2nd instance of Skype, just double-click on the shortcut that you created.
