RunDLL Error The specified module could not be found.UUS.dll
Hi there,
I uninstalled a program and after I reboot my PC this RunDLL error appeared. This error appears every time I open my PC. After some searches on the Internet I didn’t find anything. I would like to know if I install the program again this error will disappear. How can I fix?
Thank you!
Error loading C:Program FilesCommon FilesParetoLogicUUS2UUS.dll
OK
Answered By 590495 points N/A #189901
The error originated in the “common files” folder which is not common when a program was properly uninstalled. This can happen if the application was uninstalled incorrectly or the process returned or end up incomplete leaving portions of the program still on the system and this can result to system errors. Because this error was committed after uninstalling your application, the best way to deal with it is to reinstall the program.
Once it is installed again restart your computer. Next, click Start, Control Panel, and then Add or Remove Programs. Select your program from the list and click either Remove or Uninstall to uninstall the application. When it is finished, click Start, All Programs, Accessories, System Tools, and select Disk Cleanup. Select drive C and click OK.
Check “Temporary files” and click OK. Wait until it is finished and restart your computer. If you wish to use your program again, it would be better if you install the latest version. Since I’m not sure what ParetoLogic product you are using, download your software again from ParetoLogic Security and Utility Software. This way you are sure you are using the latest.
