RunDLL, Two Error Messages Appear
Hi!
I would just check here since I guess its not exactly normal.
The only problem I've been having lately is that this Message always appear.
Hi!
Those message appear because those files might have been infected and when you ran AVG and it quarantined it, It became inaccessible so the programs that needs those to run can not find it thus the message.
If you are planning on using System restore to fix this, your 20GBÂ of music files will not be deleted when you run system restore since system restore only affects installed programs, system registry and recent driver changes.
Keep in mind that when you use system restore, there is a probability that your infected files might get restored as well so run your anti virus after your system restore.
