Running 120mm fans from a single 4-pin on the motherboard
60 points
Posted on - 07/07/2014
I am trying to run two 120mm fans from one 4-pin motherboard connector. I wonder if this is fine or not. I am allowed to control profiles of fan speed in the BIOS so I can have run it quiet and cool. Will it draw too much current? If so, can I tap into the 4 pins that are unused from the CPU power cable?
