Running print server in an Intranet
Posted on - 02/07/2015
I have a local intranet that has several submasks and I have been running web servers without a problem due to the default gateway being fixed, however I was planing to install a print server and run this along the print server. Would I need to change my Ip address so that I can capture the default printer. I use a multi system that comprises both windows and Linux and the printer in supported in a Linux platform
