Hi All,
I'm having a lot of trouble getting DRM content to play on WMP11 under Vista
Business SP1.
I have followed the Microsoft KB advice and reset my DRM store and then tried to upgrade the security component while I got an error message: "Running this process under a debugger while
using DRM content is not allowed".
Here is a picture to better describe my problem.
Can't Play
Summary:
Running this process under a debugger while using DRM content is not allowed.
Error Code:
C00D2767
web help
Can anyone help me please?
Scot1984
15 points
Error on running DRM in WMP11
There may be the below listed causes for the issue playing DRM in windows media player.
- The computer processor has been changed.
- The computer motherboard has been changed.
- A basic input/output system (BIOS) setting that affects the computer hardware has been changed. For example, hyper threading has been disabled.
- The hard disk on which the media content was originally downloaded has been moved from one computer to another computer.
- An application, such as the RegClean utility, changed DRM settings in a way that caused corruption.
- Microsoft Windows has been reinstalled on the computer.
To fix the issue…
1. If Windows Media Player 11 is running, exit Windows Media Player 11.
2. Locate the DRM folder on the hard disk, and then rename the DRM folder to DRMbackup.
1. Visit the Microsoft website to learn more about the DRM system.
2. Follow the resolutions to resolve the DRM issues that you are encountering.
It is possible that the DRM that you installed is not in good condition, it may be corrupt and therefore it did not install properly. The components of the application may be corrupt, and therefore you will need to try the following to resolve the problem that you are getting:
First, you will need to check the system specifications on your computer.
And then go to the internet and search for the DRM application that meets those system specifications.
From whichever site you download, make sure that it is a trusted site, and also check other users comments about it to find out if the application is worth downloading or not.
Download it and install it.
Try using it to play the on WMP again.
-Clair Charles
kwashd
Answer:
Run: MSCONFIG
Click: BOOT tab then
Click: ADVANCED OPTIONS
Uncheck: DEBUG under DETECT HAL
Click OK: to Remove ADVANCED OPTIONS dialog
Check: MAKE ALL BOOT SETTINGS PERMANENT in MSCONFIG dialog
Click: APPLY
Click: YES for warning dialog
Click ok: to remove MSCONFIG dialogue
RESTART your computer
Reasons:
The reason for the problems is that you interfered with boot settings. but will work once the process is completed as stated above restart and enjoy URL is :​ WMP 11 Debugger error in Vista
