jamesmsdn
Posted on - 10/31/2011
I obtain various operating systems with permission of MSDN by VMWare. For user improvement I was applying virtual machine till its working condition and running on XP Pro environment from last 3 years.
 For cleaning purpose I received all brand new updates.
Today when I start my work I got message for activation but after click I got 32777 error.
I have search help in official website but no connectivity. After having genuine OS from MSDN, I setup on VM and never shifted.
Now I want to get problem point…
Running Virtual Machine with Microsoft XP Pro
It is possible that Internet Explorer is having a problem with the Certificate Revocation turned on when doing the activation.
Try turning off this option by following these steps:
Launch Microsoft Windows Internet Explorer.
Click Tools > Internet Options.
Click Advanced tab.
Under Settings, in Security category, uncheck Check for publisher’s certificate revocation and Check for server certificate revocation (requires restart) options.
Click Apply and then OK. Close Windows Internet Explorer.
Go back to your previous task and then activate what needs to be activated. After the activation has successfully finished:
Launch Microsoft Windows Internet Explorer again.
Click Advanced tab.
Under Settings, in Security category, see Check for publisher’s certificate revocation and Check for server certificate revocation (requires restart) options. These are the options that were previously disabled.
Click Apply and then OK. Restart Windows Internet Explorer.
