Michelle
Posted on - 02/04/2012
I am getting a runtime error R6002 when loading certain webpages such as Google Chrome, Safari, TrueCrypt and more. I scanned my whole system but found nothing. I also cleaned my registry through CCleaner for almost five times now. Can someone please tell me what is happening here? Thanks.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: ED…
R6002
-floating point support not loaded
Runtime Error R6002 when loading web pages
Hi Michelle,
You need to keep your windows registry safe and functioning properly to be able to eliminate such errors and stops others before they start.
One of the most important things is to take a thorough look at your registry and fix it if necessary. It may be a very difficult process if you do it manually but I recommend you to try it if you don’t want to install registry tools.
But if you want it more easier and faster solution to handle this situation is to install and employ a specialized registry repair tool. Registry repair software was developed by engineers to carefully and completely analyze and fix a faulty windows registry in just a few minutes.I hope it might help.
Zorian
