Runtime error in using TileRacer.
I’m using TileRacer, which is a version before .701, and I’m getting this error continuously.
Please help me to solve this issue.
I couldn’t find any help in the official website. Please help.
The error is runtime. Means the working environment, means the parameters to the execution to the program are improper for running in real time which means a runtime error.
This considers the following.
1.      The system requirements for the functionality do not meet as desired.
2.      The minimum system requirements are given in the manual with the software.
3.      The data present in the disk is improper. Such error normally occurs when the graphics is not up to the mark or that the Sound card is not configured well.
4.      Ensure that The Software package is obtained from a reliable store that does not contain any Malware.
Check the system requirements for the program and make sure you are trying to run a valid program for the OS you are using also check your program is supported by 32bit or 64 bit windows OS.Â
Smith Thompson
