S C C M 2012 Permission Errors
Hello experts
I think I have a problem with permissions however I am able to write to the files that are in inquiry.
Here are a few screen shots of the error messages I am receiving.  I am also logged in the admin right as well as I have attempted my own domain admin account as well.
I set up MDT, then the PXE problems started so after that I uninstalled it as well as then still I could not PXE boot as a result I launched poking around. Then I found all these error messages.
I have run this similar Installer, Image and Boot Images in many times.
Configuration Manager
Image source is not available. Verify that the source is available
and Configuration Manager has the appropriate permissions to
access the source.
                                                               OK
What should I do now? Please help.
Thanks in advance.
Answered By 10 points N/A #151244
Hello Kathy,
Try the following workarounds and see if they will help solve the problem:
  • Try running  a site reset and then go through the wizard. Try going through all the permissions available for the application.
  • Try removing the PXE and then after hat reboot the machine, and then re-enable the PXE again.
  • Try acquiring the DP role on the site and after that restart, and then add it back, and then you will have to get rid of the remote installer.
  • Check if you have added your computer account of the site to NTFS as well as the share permissions. Those are computer accounts that enables access to the courses.
  • You can as well add a cmd command in the system context on its site server as a matter of troubleshooting the issue further.
Carl
