Safari and iPad comparison and performance
I need some help here guyz,
Is Safari better on the iPad compared to the iPhone? Â How is its performance if you try to load a page using the thumbnail browser?
Thanks in advance,
Doug
Thanks in advance,
Doug
I think Safari is better on the iPad compared to the iPhone. Because I used both Safari with iPad and iPhone and found that Safari is better on the iPad. In the issue of internet services they both look same.
No big difference between them. But compare with other figure they have differences and Safari is best.
Thumbnail browser is good in this case. It will perform 12 kbps to 32 kbps for loading a page or more than that. It is not only depend on browser but also on Safari‘s system of capability. But it is good at over all.
Hi Doug,
I have an iPhone and an iPod touch, Safari is the same on both but when i experienced an iPad, I was amazed to see that there is not much difference on them. The only thing is, iPad has a larger screen, thus better viewing.
I can also say that the processor definitely affects Safari's performance, for example my iPod touch is an older generation, thus the processor is definitely slow. The iPad on the other had its way much faster because of the dual core processor.
Here is a few links about Safari on both iPhone/iPod touch and iPad.
PS: I am using a Mac and Safari is running best compared to other devices.Â
Hope this helps,
Tony Starks
