Safari showing error message- what to do?
I have installed developer preview Mac OS X 10.7 Lion.. but now my safari is showing this error message "safari can't open the page" what should i do?
Need immediate help.
hello there BdLord the error you are specifying is a security alert. my first suggestion is to check your time. check your clock if its set into correct time and date. well if you are sure that your time and date is correct then the problem is you are opening a webpage that contains malicious contents or threat contents that can affect your computer. most of the browser has security features like this.
hope this will solve your problem have a nice day!
Dear User,
This is not usually an error. This is of course a warning. An alert.
But however you can check your system time and date settings. If they are not correct that also could result in such a problem.
And still you are getting this error message, it is better that you stay away from this site , safari warns you because there is a reason for it. The website you are trying to access might not be safe
Thank you.
.Â
