Hannah
270 points
Posted on - 05/10/2011
I have a set of electronic documents on my office computer. I am changing offices and I need to wipe out the information off the office computer. How can I do this without using a third party software ?
WhizBoy
Safely wipe out data without using a third party software
When you delete files from a computer, what actually happens is that the file pointer entry in the FAT table is changed. This means that the "entry point" to your file is erased, whereas the body of the file remains intact. There are tools that can recover the body part, thereby effecting a recovery. It is actually difficult to ensure the file is totally wiped out without actually using a third party tool to do it.
MathGirl
Its going to be difficult but you can do a combination of things to ensure its going to be "hard to recover".
The first step would be to empty the recycle bin.
There are recycle bins in each drive. So ensure you empty the recycle bin fully.
The next step I would take is, to copy a big file to the same location where the private documents were.
WhizBoy
If you are using windows XP, I would suggest you run the disk defragment utility as well. The disk defragment utility re-allocates the hard disk clusters so that mostly used programs are put first and the subsequent static data last. There is a chance that this procedure will put a block of data from another file to the location of the files that you want removed. It is to be noted that you need to do this with your virus scanner off. Else it will take a long time.
Hannah
270 points
I did both the above suggestions. The office computer has two disk partitions. The documents I have are on the second drive. So I deleted the files, emptied the recycle bin as well. Then i copied a big movie file as well. Then i ran the disk defrag utility. I would think now that the files are totally gone! Thank you!
WhizBoy
Wait! Did you mention you have 2 disk partitions? Well you can do a disk format on the second partition. You can copy all the required files to the first partition. Then you can do a disk format on it.
Right click the drive
Select Format
Say "yes" to the warning box.
ENSURE you pick the option for a FULL format (not Quick format)
If you do a double format, i.e. format with Fat32, and then again with NTFS, your files will be truly gone!
MathGirl
Whiz Boy! That is a fantastic idea! I am sure the double formatting will work!
Hannah
270 points
Thank you Whiz Boy! I did as advised. It never occurred to me to format the disk. Even I am now pretty confident that the files are wiped out. Thank you again!
