I have Sage Software to account for my daily expenses and transactions but today I received this exception error. I really can’t understand this kind of error so I need your help to fix this problem. I am sure you can fix this error. I will be thankful to you.
Sage 200 System Administration
Exception has been thrown by the target of an invocation.
Sage 200 System Administration Error
There are different reasons why this error is thrown by the program. One is when you want to create or add a menu via advance mode where the error comes in on the logon user step and throws the “Exception has been thrown by the target of an invocation” error. The reason for this is that you cannot logout anyone from the system if they are actually logged in.
If the system believes they are logged in because of a disconnection, you should login to the core system then go to Accounting System Manager, Utilities, and then User Login Status. Any users in the Disconnected tab can be selected and then click Log Off. This will only clear disconnections but will not boot any one out who is literally logged in.
