Same column in a Table shortcut
Which one of the following is a shortcut for going to the beginning of a column in the same column in a table?
Hi Jagodish,
You can use Ctrl+Home to view the column in the beginning and Ctrl+End to view the column in the end of it. Is there any further information about it? Can you please provide me some of it?
Thank you in advance. That’s my answer.Â
Hi Friend,
I provided you a simple and ease shortcut on how  to use MS Word in a table and some of the shortcut that you need enable to use MS Word. Hope It can Help….. Here Are some
ctrl+z / y |
Undo / Redo the last action. |
arrow left / arrow right |
Move one character to the left / right. |
ctrl+arrow left /ctrl+arrow right |
Move one word to the left / right. |
arrow up / arrow down |
Move one line up /down down. |
ctrl+arrow down /ctrl+arrow up |
Move to the next/ previous paragraph. |
home / end |
Move to the beginning / end of the line. |
ctrl+home / ctrl+end |
Scroll to the top/ bottom of the current page. |
page up / page down |
Scroll up/ down in the current page. |
ctrl+backspace /ctrl+delete |
Delete one word to the left / right. |
ctrl+x / ctrl+c / ctrl+v |
Cut/ Copy/ Paste the selected text or item. |
ctrl+b |
Apply or remove bold formatting from the selected text. |
ctrl+i |
Apply or remove italic formatting from the selected text. |
ctrl+u |
Apply or remove the underline from the selected text. |
Hi Friend,
I Provided you a simple and Ease shortcut on how to use MS Word in an appropriate way. Just hold down Ctrl and press Home or Ctrl+Home, this shortcut command will Automatically execute on the go  in the beginning of Current column of Table in MS Word or in  the top of  current page that you are working for… Hope It can help.
