Samp – server.exe – bad image error
Hi friends,
I have OS windows XP on my system. I recently downloaded the server files from the link, but I am unable to run the MS DOS screen as the server ends up I the following error.
The screenshot is attached below:
The message states:
C:windowssystem32MSVCR100.dll is either not designed to run on windows or it contains an error. Try installing the program again using the original installation media or contact your system administration or the software vendor for support.
Any help in this regard will be highly appreciated.
Looking forward to your suggestions.
Thanks in advance.
Regards.
