Sample 3d vertices array free download
Hi guys,
What is a 3D vertex array?
I know this concern to OpenGL, but I am not familiar with it.
Please tell me where I can get sample 3D vertices array free download.
Hi guys,
Hello Stanton Snider,
I am giving you some references for your better guidelines.
// BEGIN INITIALIZATION
// Define some vertex data
struct Vertex {
GLfloat position[3];
GLfloat texcoord[2];
Vertex vertexdata[NUM_VERTS] = { … };
GLubyte indexdata[NUM_INDICES] = { 0, 1, 2, … };
// Create and bind a VAO
GLuint vao;
glGenVertexArrays(1, &vao);
glBindVertexArray(vao);
// Create and bind a BO for vertex data
GLuint vbuffer;
glGenBuffers(1, &vbuffer);
glBindBuffer(GL_ARRAY_BUFFER, vbuffer);
// copy data into the buffer object
glBufferData(GL_ARRAY_BUFFER, NUM_VERTS * sizeof(Vertex), vertexdata, GL_STATIC_DRAW);
// set up vertex attributes
glEnableVertexAttribArray(0);
glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, sizeof(Vertex), (void*)offsetof(Vertex, position));
glEnableVertexAttribArray(1);
glVertexAttribPointer(1, 2, GL_FLOAT, GL_FALSE, sizeof(Vertex), (void*)offsetof(Vertex, texcoord));
// Create and bind a BO for index data
GLuint ibuffer;
glGenBuffers(1, &ibuffer);
glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, ibuffer);
glBufferData(GL_ELEMENT_ARRAY_BUFFER, NUM_INDICES * sizeof(GLubyte), indexdata, GL_STATIC_DRAW);
// At this point the VAO is set up with two vertex attributes.
// referencing the same buffer object, and another buffer object.
// as source for index data. We can now unbind the VAO, go do.
// something else, and bind it again later when we want to render.
// with it.
glBindVertexArray(0);
// END INITIALIZATION
// BEGIN RENDER LOOP
// This is it. Binding the VAO again restores all buffer
// bindings and attribute settings that were previously set up
glDrawElements(GL_TRIANGLES, NUM_INDICES, GL_UNSIGNED_BYTE, (void*)0);
// END RENDER LOOP
Best Wishes.
Notifications
