Sample Code for ComponentOne VB Using MYSQL Connector?
andrew word 30 points N/APosted on - 04/27/2013
Good Day Friends!
Do you know how to use ComponentOne Visual Studio Express? Can you provide sample codes for ComponentOne VB using MySQL connector? Also, can you provide a simple tutorial on how to use ComponentOne with the sample codes to insert , update , delete and backup database ? Any help will be greatly appreciated.Â
ComponentOne visual studio has several platforms , it enables programmer to build desired application easy , it has more powerful features at new versions,you can build Desktop application , .net (web application) iPhone and more as you want.
What are inside it:
1- WinForms                  For building windows based application
2- WPF                            Is graphical subsystem for rendering user interfaces,
3- ASP.NET Wijmo         For web based application it has CSS,html and jQuery for using with ASP.Net  Â
4- MVC                             Model View Control Pattern for building object orient application  Â
5- Silverlight                 For web UI design
6- WinRT XAMLÂ Â Â Â Â Â Â Â Â Â Â Â Â Â For building better Windows Store apps.
7- WinJSÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â UI components controls for JavaScript designers
8- Windows Phone        Phone 8 controls for data visualization, rich text editing, data input, PDF viewing, and more.
9- Compact Framework Responsible for Grid, chart, validation, and zip controls for building Mobile apps.
10- ActiveXÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Full suite of the most popular ActiveX components including controls like True DBGrid and VSFlexGrid.
These above are the controls in componentOne visual studio about using it there are videos tutorials
– The next is code(Attached in text file) example to connect to MySQL database through component one
1....
