Sample code for quiz in vb 6
Anyone give me some idea about to create quiz in vb 6 or give me some sample codes, which can be used for quiz in vb 6.
Hi Caspian zec,
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to get Sample code for quiz in VB 6.
So classifying and posting them on relevant forums is the best way to get your answer step by step. I can suggest you some good forums, which are listed below:
If you want to create sample codes for quiz of VB 6.0 then you have to use the array style of radio. As you know that there are different numbers on radio button so you have to use that array of numbers from 1 to 0 and then you will find the results which you are looking for.
