Sample SQL Code for Veeam Database
Hello and Good Day Experts!
Hello Williams,
This situation describes how to use the Microsoft SQL revival wizard to carry out a specific query alongside a specific database and re-establish the query consequences. You can save the consequences of the query back to the construction record or save them as data files to a detailed file.
If you desire to refurbish the outcome of the query to the construction database, the Microsoft SQL re-establish wizard will generate a new board in the preferred database on the fabricated Microsoft SQL Server and insert the query results.
For details,
See Scenario 3.2. Restoring Query Results to Data Files
Hi Naomi,
To enter and execute SQL statements or commands such as SELECT, INSERT, UPDATE, DELETE, BACKUP, and RESTORE, input the statement or command at the SQL prompt.
       For example:
       If you want to select customer name and email from the Customer Table, command should be:
       SQL > SELECT customer name,email FROM Customer;Â
       For example:
       If you want to insert Eric James, [email protected] in the Customer Table, command should be:
        SQL > INSERT INTO Customers
        VALUES ( 'Eric James', '[email protected]')
        For example:
        If you want to update the email address of Eric James in the Customers Table, command should be:
        SQL > UPDATE Customers
        SET Email='[email protected]'
        WHERE CustomerName='Eric James'
       For example:
       If you want to delete customer ID of Eric james, command should be:
        SQL > DELETE FROM Customers
        WHERE CustomerID='1'
       SQL > BACKUP DATABASE database
       SQL> RESTORE DATABASE database
