SampleGrabberis not registered error on CapDVHS
I'm trying to record through Firewire with IEEE 1394. I followed the steps on a certain website and then plugged in my firewire cable to DT100. However, starting the CapDVHS to enable the STOP and REC buttons doesn't work. A unfamiliar error appears and I'm not sure what it means and how I can fix it. Can someone please send me some help and fix this issue? Thank you in advance.
ERROR
SampleGrabberies not registered.
For the record, I am running Windows 7 x64 and I'm not sure if someone here already tried to capture using a JVC 30K machine with CapDVHS to Windows 7 x 64. And I'm not even sure if this will really work.
