Samsung App Installing Talking Bada Bear
How to install the latest Samsung kies from Samsung website? Is this available on all region/country?
You can download the Samsung Kies. The latest version of Kies is 2.3.0.12035_16_4 check first the specifications, such as 500 MB drive space, Windows XP or higher OS, indicated below before installing. After downloading, follow the steps on how to install Kies located below the download button.
Kies is available to all countries but in case you didn't find your country of preference, you can search for it during the installation. A country flag of where it is serviced is located at the bottom of the app store. Click on it and choose the country that you would like.
Good luck!
Yes, of course, Samsung Kies is available and can be downloaded by all users in all parts of the world as long as you have the device where you will be using it. In the Philippines, Samsung Kies can be downloaded from Samsung | Kies. If you will be downloading the software, the site automatically detects your present location and directs you to the page specific for your country or region to make the information appropriate for your country’s preference.
Samsung Kies is available for Microsoft Windows and Mac OS X operating systems. And before installing this software, first make sure to download and install Microsoft .NET Framework 3.5 Service Pack 1 or later, and Windows Media Player 10 or later to make the installation work. For Microsoft Windows, it also requires that your operating system already has DirectX 9.0c or later which I hope is already available in your platform. To use the software, you need to connect your Smartphone to your computer using its USB data cable but if you don’t have it you still can connect it using the phone’s Wi-Fi feature.
Notifications
