Samsung ATIV Book 9 2014 Edition Verses Lenovo Yoga 3 Pro
Focusing on performance and battery life, can the Lenovo Yoga 3 Pro be considered better than Samsung ATIV Book 9 2014 Edition? What are some of the distinct and vital features of Samsung ATIV Book 9 2014 Edition as compared to Lenovo Yoga 3 Pro? In your own view which of these two machine is worth priced high considering all other factors such as model design, material for manufacturing and so on.
Answered By 590495 points N/A #189781
The Lenovo Yoga 3 Pro laptop comes pre-installed with either Microsoft Windows 8 or Microsoft Windows 8.1. It runs on Intel Core M 5Y70 1.1 GHz processor, Intel HD Graphics 5300 GPU, and 8 GB RAM. It has 256 GB SSD (Solid-State Drive) internal hard drive. It has a widescreen display at 3200 x 1800 pixels native screen resolution with screen size at about 13.3 inches.
It weighs at about 2.6 pounds. It supports Wi-Fi 802.11ac (2.4+5.0 GHz dual-band) and WiDi. For technical support, they offer 1 year depot or carry-in repair. The standard battery rundown time is about 8 hours 19 minutes. The Lenovo Yoga 3 Pro laptop is an enormously thin, fanless design. For the downside, it has a very shallow keyboard. The micro HDMI port needs an adapter to be able to use it with a standard HDMI.
The Samsung Ativ Book 9 2014 edition laptop is pre-installed with Microsoft Windows 8.1. It runs on Intel Core i5-4200U 1.6 GHz processor, 8 GB RAM, Intel HD Graphics 4400 GPU, and 128 GB SSD internal hard drive. It has a widescreen display at 1920 x 1080 pixels native screen resolution with screen size at about 15.6 inches. It supports Wi-Fi 802.11ac and weighs 3.92 pounds.
For technical support, they offer 1-year warranty for parts and labor. The standard battery rundown time is about 11 hours 26 minutes. It is slimmer and much lighter design with a rather larger display than the previous version. Supports full size HDMI port. For the downside, it costs a little higher than the previous version. For Ethernet and VGA, user needs to use dongles.
It only displays full HD instead of Quad HD+ which was available on the previous version.
