Hello, I have a Samsung F5800 Plasma TV in my office. I am facing a problem with it for last few days. Every time I turning it on, it pops up a message that says " Un-identified input or bad connection". I have checked all the connections thoroughly, nothing found. Can any person help me out please?
Samsung F5800 Plasma TV is showing message unnecessarily.
Firstly you need to check is there any welcome message set by default in this TV. If it's not kind of welcome message and if it's a setting error message then you need to configure the settings correctly.
Even if it does not work try resetting your complete TV settings to default/factory restore.
At last if even this does not solve your problem, you may need to contact customer support team.
