Samsung Galaxy applications for Android
It depends upon the application and the compatibility to your device. Some applications cannot be installed without rooting your mobile phone for you to have permission installing some application to your mobile device,you have to root your phone.
For example,you have galaxy phone "galaxy y" you need the universal ginger root. zip. While you have the file,save it to your sd card then turn off you phone. Then hold volume up,home,power on. When you are in recovery mode choose apply update from zip. Then select update. zip/universal ginger root. zip,wait for a while until it's finished then viola!Your galaxy device is now rooted.
I don’t see any problem here why an application from a Samsung Galaxy Smartphone will not run on other Android Smartphone since Samsung Galaxy is also an Android phone. But it really depends on the application’s supported Smartphone operating system. There are Smartphone applications that require newer versions of Android for it to be installed and there are ones that is only intended to run on 1 particular version.
The solution really depends on the kind of application that you’ll be downloading and installing. To be sure that you will not encounter any problems with the application you’ll be downloading on your Samsung Galaxy Smartphone, you should not forget to check the specifications of the application before actually downloading it.
