Samsung Galaxy Beam in India
I want to know when will Samsung Galaxy Beam be available her in India? I really want to try out its projector properties.
At MWC 2012 Samsung has exposed its new products along with a mobile phone ‘Galaxy beam’. This is the first smart phone projector combo with dual core CPU that has been produced by Samsung. Its 15 lumens projector allows user to demonstrate a multimedia content large luminous projector screen – walls, ceilings or flat surfaces.
The probable release date of Samsung Galaxy Beam in India was July 2012. and it has been released as date mentioned. Now you can buy it in India for Rs. 29, 9000. its now available in Samsung e-stores on pre order payment. That means if you want to have it you have to pay the amount at the beginning.
The Samsung I8530 Galaxy Beam Smartphone supports 2G and 3G networks. It was unveiled in February 2012 and released in July 2012 and supports mini-SIM. It measures about 124 x 64.2 x 12.5 millimeters and around 145.3 grams in weight. It has a TFT capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution.
It supports multitouch with TouchWiz UI v4.0 and integrated with nHD projector. It supports 3.5-millimeter jack, microSD expandable up to 32 GB, and 8 GB internal storage running on 768 MB RAM. It supports microUSB 2.0 and Bluetooth 3.0 with A2DP and HS. The primary camera supports 5 megapixels at 2592 x 1944 pixels resolution with autofocus and LED flash.
It features geo-tagging, face and smile detection, touch focus, and can do video recording in 720p at 30 fps. The secondary camera supports 1.3 megapixels. It runs on Android 2.3.6 Gingerbread powered by NovaThor U8500 chipset with dual-core 1 GHz Cortex-A9 processor and Mali-400 GPU. It can be upgraded to Android 4.1 Jelly Bean.
It supports HTML and Adobe Flash for internet access with Java support via Java MIDP emulator. It has a standby time of up to 760 hours on 2G and 3G and talk time is up to 20 hours on 2G while 9 hours and 40 minutes on 3G. It costs around 300 Euros.
