Samsung Galaxy Blaze Q mobile
Samsung is going to launch its new mobile Galaxy Blaze which is going to come into market from T-mobile. I want to know what features and specifications it provides.
Hello Mam Tiffany,
Upon researching about your questions here are some details that I provided for you to help you get your answers. Samsung Galaxy Blaze Full Spec:
Hope that I did help you have a nice day.
Hello Mam Tiffany,
Here I am providing you the key features and specifications of Samsung Galaxy Blaze mobile.
To speed up its operating system bears1.5 Hz dual-core processor and it is 4G enabled speeds. For your entertainment it includes a 3.9 inch screen. It has the capability to direct you with voice talk.
Key specifications:
1. Its carrier is T-Mobile.
2. Its platform is an android.
3. 39 inch wide display size.
4. Its camera supports high resolution which is 5.0 Megapixel.
Thanks for your question.
The Samsung Galaxy S Relay 4G T699 is also known as Samsung Galaxy S Blaze Q for T-Mobile. It is a 3G device operating on 2G, and 3G bands using GSM, and HSPA technologies. It was unveiled to the public and released on September 2012 and is currently available. It measures 126 x 66 x 13.5 millimeters and weighs 147 grams.
It uses a mini-SIM card. It has a Super AMOLED capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch. It runs on Android 4.0 Ice Cream Sandwich powered by Qualcomm MSM8960 Snapdragon S4 Plus chipset, Dual Core 1.5 GHz Krait processor, and Adreno 225 GPU. It supports microSD expandable up to 32 GB.
It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels at 2592 Ñ… 1944 pixels with LED flash and autofocus. The camera features geo-tagging, face detection, and touch focus. It can record video in 720p at 30 fps. The secondary camera supports 1.3 megapixels. It has Wi-Fi 802.11 b/g/n with Wi-Fi Direct, DLNA, and hotspot; Bluetooth 3.0 with A2DP; GPS with A-GPS; NFC; and microUSB 2.0.
The Samsung Galaxy S Blaze Q has built-in accelerometer, gyro, compass, and proximity sensors. The pre-installed web browser supports HTML5 with Adobe Flash. It doesn’t support Java. It runs on Li-Ion 1800 mAh battery with standby time up to 312 hours. Talk time is around 10 hours.
Notifications
