Hello!
 I need help as soon as possible. I installed ROM Android Market Manager on my Samsung Galaxy Mini (with OS Android 2.2 Gingerbread installed) and also I installed clockworked recovery. I tried to back up the current ROM and the cell phone turned off suddenly. It does not turn on in any mode: downloading mode or even in recover mode. No response at all even when you stick the charger or when I press any key.
Did you experience that? Do you have any solutions?
Please help me.
Laurentiu.
Samsung Galaxy Mini suddenly turned off and does not turn on anymore
Good Day,
Here is the Solution for you Cell Phone.
Clockworkmod also known as Clockwork and CWM  is a custom recovery for Android phones and tablets that allows you to perform several advanced recovery, restoration, installation and maintenance operations on your Android device that aren’t possible with the stock recovery. In what follows, we will cover all that this recovery is capable of doing, and how to do it.
Booting into ClockworkMod
Once you have ClockworkMod recovery installed on your Android device, booting into it is quite simple. All you have to do is launch ROM Manager and tap ‘Reboot into Recovery’.
Also, if you have ADB installed on your computer, you can simply enable USB debugging mode on your device from Settings > Applications > Development, connect it to your computer via USB, launch a Command Prompt / Terminal window on your computer and enter this command:
adb reboot recovery
The above methods will not work in certain cases though, for instance if you can’t boot into Android in the first place due to some issue, or if you are using a device like the HTC HD2 that doesn’t natively support an Android recovery. Many solutions are available in these cases.
ThanksÂ
Abdul Sabur
dlanear
5 points
Installation failed. That's the main cause of this problem. the installed program is not compatible with the Operating system. Better ask assistance with the manufacturers site to revive your phone. For your security not to happen this again, download the software for those eligible sites in the web.
-Dlanear.
