ef2011
470 points
Posted on - 11/05/2013
Samsung Galaxy Note 3 features
What are the major issues on this device?
I wanted to know the Pros & Cons of Samsung Galaxy Note 3
Can anyone enlighten me with this
Samsung Galaxy Note 3 has a lot of features and has a lot to offer than you can just imagine. Galaxy Note 3 has a lot of reasons to be preferred over iPhone 5 or any other smartphone.here are
some listed:
4.8 inch bigger screen – which allows you to enjoy movies on a big Gorilla glass screen.
720p video recording
Remove able batteries
1.4 GHz quad core processor with Android Ice Cream Sandwich v4.0 OS
16 GB internal memory, extendable upto 64 GB with micro SD card
Amazing S-beam technology – allows you to share data by just placing your phone to a compatible device
Can be used as USB flash drive with file explorers.
Perfectly designed multi-tasking
Light in weight despite of the large size
Slim body feels great to hold
Some of the issues that are reported with the device are regarding its battery life and long delay in jelly bean update. Overall Galaxy Note 3 has captured the market even when Galaxy S4 was on the go.
Hello.
One of the best from SAMSUNG.
It has
1. 4.8 inch bigger screen – which allows you to enjoy movies on a big Gorilla glass screen.
2. 720p video recording
3. 1.4 GHz quad core processor with Android Ice Cream Sandwich v4.0 OS
Hello Ef2011,
Samsung galaxy is undoubtedly one of the best smartphones out there. It has some great features to shake our heads off. And it is the first phone ever to have 3GB of ram. Now lets talk about some features, Pros and Cons.
Features:
3 gb of ram.
5.7 inches screen and 8.3 mm in thickness.
Corning gorilla glass 3
Resolution is 1080 X 1920 pixels and ppi is greater than 386
Up to 64 gb expandable storage.
13 MP camera in front with, simultaneous video and image recording, Dual shot, 2mp rear camera.
Android Jelly bean 4.3
EXYNOS 5 octa 5420 Chipset.
Graphics adreno 330
CPU quad-core 2.3 GHz
Accelerometer, compass, barometer, humidity, proximity, temperature, gesture sensors.
S-voice, gesture, smart sleep feature
Supports 4G.
Pros:
Very big display
High resolution
Extremely high ppi
quad core processor
fast mobile data support
lots of ram
HDMI connector
S-pen
S-voiceÂ
Expandable memory
Cons:
Expensive
Poor low light camera
Complicated to use
Hope this helps!
Thank you,
Wagner Desantiago
