Samsung Galaxy Note 4 vs iPhone 6 Plus
I would like to update my Samsung Galaxy Note, but I cannot decide if I should move to the new iPhone 6 Plus.
Is there a significant difference between the two devices? How do they compare on some basic functions (i.e. display resolution, power, camera…)? And, ultimately, which one is the best at what it does?
Answered By points N/A #135595
Both Galaxy Note and iPhone 6 are best in their own field. It’s too hard to compare both because of their differences.
Samsung Galaxy Note is powered by Android, the most popular mobile OS for every phone. On the other hand, iPhone 6 runs with iOS 8. In this case, you must make sure that which one you’re comfortable with. Both are different and covers different features.
In the case of CPU, both equals as both runs with 1.4 GHz processor and 1 GB RAM.
The graphics of iPhone 6 is many times better than Galaxy Note, 1080p at 60 FPS where Galaxy Note comes with 1080p at 30 FPS. Camera and video performance is better in iPhone than Galaxy Note.
Depending on the features of iPhone 6 and Samsung Galaxy Note, I recommend you to upgrade to iPhone unless you’re a freak of Android and need a larger display. If you need better performance and graphics, you should choose iPhone.
It’s all up to you.
