Samsung Galaxy S WiFi 4.2 Media player support
Having a 4.2 inch screen could be suitable for watching videos and other media files. What are the types of media files does the Samsung Galaxy S WiFi 4.2 media player support?
Hi JudithLBarton,
The Samsung Galaxy S WiFi comes with Android 2.3.5 and offers support for almost every video format available.
The video player will latterly support every common format you will offer it. The problem is actually in the processing power of it since it has only 1 GHz processor making it a hard job for the Samsung Galaxy S WiFi to handle High Definition videos what ever the format they are. So you should check your choice again if you are a fan of carrying HD movies to watch on this device.
Hope this helps.
The Samsung Galaxy S Wi-Fi 5.0 is a Smartphone that doesn’t support cellular connection and cannot be used for GSM voice communication, MMS, or SMS. It was announced to the public on February 2011 and released on May 2011. The Samsung Galaxy S WiFi 5.0 Smartphone has already been discontinued and is no longer in circulation.
It measures 141.3 x 78.2 x 11.9 millimeters and weighs 182 grams with Optical track pad support. It doesn’t support SIM card. It has an LCD capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch with TouchWiz UI support. It runs on Android 2.2 Froyo powered by 1.0 GHz S5P-C111 processor. It supports microSD expandable up to 32 GB.
It is available with 8 GB and 16 GB internal storage. The primary camera supports 3.15 megapixels with autofocus and LED flash support. The primary camera features geo-tagging and face and smile detection and can record video. It has a secondary camera that can record video in VGA.
It has 3.5-millimeter jack with SoundAlive support; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth 3.0; GPS; stereo FM radio with RDS support; and microUSB 2.0. It has built-in compass and accelerometer sensors. The pre-installed web browser supports HTML with Adobe Flash support. It supports Java via Java MIDP emulator. It runs on removable Li-Po 2500 mAh battery with talk time up to 8 hours via multimedia.
It is available in Black and White colors. Regarding the pre-installed media player, the following file types are supported: MP4, DivX, Xvid, WMV, H.264, MP3, WAV, eAAC+, and FLAC.
Notifications
