Samsung Galaxy S3 the “iPhone Killer”
There are some leaked in the web that this Samsung Galaxy S3 is the "iPhone Killer",
why they say it, does it has more advantage features over the iPhones?
Yes. There's actually a lot of features Samsung Galaxy S3 has that iPhone has not.
Galaxy S3 plays adobe flash and has free navigation software while iPhone has none. It can even be charged using a standard USB cable while iPhone cannot. It is enabled for wireless charging. It even has a removable battery and can be replaced if broken.
Apple Inc. will finally release iPhone 5 which will have major improvements from the previous model. It is expected to have a 4-inch-plus display, higher resolution "retina display", a bigger battery, a quad core processor and a new design.
Other features of Samsung Galaxy 3s that iPhone has not are the DLNA and near-field-communication (NFC). It has HDMI output which allows videos and movies be watched on a TV. The download speed is even 46% faster than the iPhone.
Samsung galaxy 3s has 0.5gb more RAM memory than iPhone. It has noticeably higher screen resolution and a bigger screen size.
Physically, Samsung galaxy 3s is a shade lighter and a little thinner than iPhone.
Here are the specs of Samsung Galaxy S III I9300 and see it for yourself why it is named the “iPhone Killer”. This Smartphone is a 3G device which works on 2G and 3G bands using GSM and HSPA technologies. It was announced to the public on May 2012 and released that same month. It measures 136.6 x 70.6 x 8.6 millimeters and weighs 133 grams.
It uses a micro-SIM card. It has Super AMOLED capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 2 with TouchWiz UI. It runs on Android 4.0.4 Ice Cream Sandwich upgradable to Android 4.3 Jelly Bean. It is powered by Exynos 4412 Quad chipset, quad core 1.4 GHz Cortex-A9 processor, and Mali-400MP4 GPU.
It supports microSD upgradable to 64 GB. It runs on 1 GB RAM with internal storage available in capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels at 3264 x 2448 pixels with LED flash and autofocus. The camera supports simultaneous HD video and image recording, face and smile detection, geo-tagging, and touch focus. The camera can record video in 1080p at 30 fps.
The secondary camera supports 1.9 megapixels and can record video in 720p at 30 fps. It has Bluetooth 4.0 with A2DP, EDR, and apt-X; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot; GPS with A-GPS and GLONASS; NFC; and microUSB 2.0 (MHL TV-out) with USB Host. It includes built-in accelerometer, proximity, compass, barometer, and gyro sensors. The pre-installed browser supports HTML with Adobe Flash.
The device doesn’t support Java. It runs on Li-Ion 2100 mAh battery with standby time up to 590 hours on 2G and 790 hours on 3G. Talk time is up to 21 hours 40 minutes on 2G and 11 hours 40 minutes on 3G.
