Samsung Galaxy S3 now out
Hi! What will be the specifications of this new Samsung Galaxy S3? Will this be like other Samsung Galaxy? Thanks.
Best Answer by Sharath Reddy
Answered By 5 points N/A #132686
The leaked specifications of the Samsung Galaxy S3 I have found are:
  • Quad-core 1.5 GHz Processor
  • 1.5GB of RAM
  • 16/32GB Internal storage memory
  • SD Card slot to expand memory up to 32GB
  • 4.65″ Super AMOLED III display having full HD 1080p resolution with a 16:9 aspect ratio display.
  • 12 megapixel camera, 1080p video recording at 60fps
  • Secondary 1.3 MP camera, 720p video recording at 30fps
  • 2250mAh battery
  • NFC Chip
  • Android 4.0 OS (Ice Cream Sandwich) with Touchwiz 5.0
  • 4G Network, LTE 700
  • Bluetooth v4.0 with A2DP, EDR
This S3 is far better than the other Galaxy. This Samsung Galaxy S3 seems to be better than S2 in comparison with 4G network, display resolution, bluetooth, primary camera, OS and obviously the processor.
Answered By 590495 points N/A #132687
Since the specifications of Samsung Galaxy S3 have already been posted above, I will just explain some of the features of Samsung Galaxy S3:
  • Share smarter – this Samsung handset includes the “AllShare® Play” function where you can easily share contents to friends especially to similar devices. Placing two Samsung Galaxy S3s back to back will trigger the “S Beam” feature which then automatically transfers videos, pictures, and documents between them. It also has an advanced Near-Field Communication technology or NFC.
  • Interact intelligently – the Samsung Galaxy S3 features “S Voice™ Motion Gestures” that is capable of executing tasks based on different movements or gestures. An example would simply be lifting your handset towards your ear. This simple movement will automatically convert your text chat into conversation and this is also the same gesture when you want to begin a voice call.
  • Powerful performance – Samsung Galaxy S3’s camera has 8.0 megapixels with zero shutter lag. Another feature is the “Burst Shot” function which enables you to take 20 continuous pictures and more in a few seconds. And also the front-facing camera has full 1.9 megapixels that can capture HD quality photos.
