I have Samsung Galaxy S4 smartphone recently updated to 4.3. I would like to personalize my Galaxy S4 contact list to have emoticons and emojis besides them. However, I am unable to implement this as the phone would only allow 'hearts' but not any other emojis to appear besides the contact. Is there any means to get around this and have my contact list each having a unique and separate emojis besides it? Please help
Samsung Galaxy S4 Won,t Let me Put Emoticons Besides Contact Names
You can’t put emojis in the contacts name using the stock app’ Luckily tere is a work around, First download app called true caller from here, Then got to the app and edit the contacts fro the app, Put the emojis you want The contacts noe should have Emojis on the phone app, If this didn’t workout for you, You can copy contact number and name to iPhone, And edit it with emojis you want,Then send the contact to your android phone by email, Then download the vcf file on your android phone
download this app on your android called phone: superbackup: sms & contacts from here, Open the app  , Select contacts backup, Select restore, And then select the vcf file you just received from iPhone.
The Samsung Galaxy S4 I9500 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on March 2013 and released on April 2013 measuring 136.6 x 69.8 x 7.9 millimeters and weighing 130 grams. It is built with a plastic body and uses micro-SIM card.
Samsung Galaxy S4
It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 3 with TouchWiz UI. It runs on Android 4.2.2 Jelly Bean upgradable to Android 5.0.1 Lollipop powered by Exynos 5410 Octa chipset, Octa-Core (4 x 1.6 GHz Cortex-A15 & 4 x 1.2 GHz Cortex-A7) processor, and PowerVR SGX544MP3 GPU.
It supports microSD expandable up to 64 GB. It runs on 2 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 13 megapixels featuring f/2.2, 31mm, 1/3″, 1.14µm, AF, LED flash, and HDR and supports 1080p video recording at 30 fps with dual-video rec.
The secondary camera supports 2 megapixels featuring f/2.4, 31mm, and dual video call and supports 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; and microUSB 2.0 with MHL 2 TV-out and USB Host support. It doesn’t have stereo FM radio.
It has built-in accelerometer, gyro, proximity, compass, barometer, temperature, humidity, and gesture sensors. The pre-installed web browser supports HTML5. It runs on removable Li-Ion 2600 mAh battery with standby time up to 370 hours on 3G and talk time up to 17 hours on 3G. It is available in White Frost, Black Mist, Arctic Blue, and Black Edition colors.
Now, if you want an app that will allow you to add an emoji to every contact on your phone, try downloading Emoji Contacts Manager. It requires Android 4.2 Jelly Bean and higher.
1....
