Hi, Is there any one who is using Samsung Galaxy S5 LTE? I am having a problem using it. It's display isn't working like before. I bought it not so long ago as it's a almost brand new product of Samsung. Anyone know here, why Samsung Galaxy s5 LTE display isn't responding spontaneously?
Samsung Galaxy s5 LTE display isn’t responding spontaneously
I don’t think the Samsung Galaxy S5 LTE is very old because it was only released around July of this year, 2014. If your phone’s display is no longer responding as it was before when you first bought it, try cleaning the surface of the screen. Turn off your phone then wipe the surface of the screen with a soft clean cloth.
Wipe the surface until you think it is clean. Turn it on again then see if your screen now responds properly. If you still notice a slight problem in the way your phone responds when you tap the screen or you slide your finger, try calibrating your phone’s screen. Check with your phone’s manual on how to properly calibrate the touchscreen display of your phone.
