I am planning to go for a new mobile. I was a proud user of apple 4 and the phone is still good other than the fact that the battery is weak. I am planning to buy Samsung S6 edge. Have anybody purchased it already? Has anybody used it? what are the interesting things in it? For ex. In Sony j10 mobile, I could play music for both me and the caller in background! Can I use the edge display to display my own customized texts or reminders. How is the experience so far? Is there anything which is also disliking? Please share in detail. Many Thanks.
Samsung Galaxy S6 edge performance innovation tweaks and more
Since you are interested in Samsung Galaxy S6 edge, here are its specifications. The Samsung Galaxy S6 edge Smartphone is a 4G LTE device supporting 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled on March 2015 and released on April 2015. It measures 142.1 x 70.1 x 7 millimeters and weighs 132 grams.
It uses a nano-SIM card with Corning Gorilla Glass 4 back panel. It has Super AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass 4 with TouchWiz UI and Curved edge screen.
It runs on Android 5.0.2 Lollipop upgradable to Android 6.0.1 Marshmallow powered by Exynos 7420 Octa chipset, Quad Core 1.5 GHz Cortex-A53 and Quad Core 2.1 GHz Cortex-A57 processors, and Mali-T760MP8 GPU. Unfortunately, it doesn’t support microSD. It runs on 3 GB RAM with internal storage available in the following capacities: 32 GB, 64 GB, and 128 GB.
The primary camera supports 16 megapixels with f/1.9, 28mm, OIS, LED flash, and autofocus. The primary camera features 1/2.6" sensor size, 1.12 µm pixel size, face detection, geo-tagging, touch focus, Auto HDR, and panorama. It can record video in 2160p at 30 fps, 1080p at 60 fps, and 720p at 120 fps with HDR and dual-video rec.
The secondary camera supports 5 megapixels with f/1.9, 22mm and can record video in 1440p at 30 fps with dual video call and Auto HDR. It has 3.5-millimeter jack; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot; Bluetooth 4.1 with A2DP, LE, and aptX; GPS with A-GPS, GLONASS, and BDS; NFC; infrared; and microUSB 2.0 with USB Host support.
It has built-in fingerprint, proximity, compass, accelerometer, gyro, barometer, heart rate, and SpO2 sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on non-removable Li-Ion 2600 mAh battery with talk time up to 18 hours on 3G. The Samsung Galaxy S6 edge Smartphone is available in Gold Platinum, White Pearl, Green Emerald, and Black Sapphire colors. It is priced at about 510 Euros.
